Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
 Post subject: KN variator problems...
PostPosted: Mon Jan 07, 2008 3:37 pm
just got my new variator from BSS, I went ahead and installed it on my 05 ruck and now I'm having some trouble, with the KN variator in and 6g weights, I am only able to hit 36 while hitting the rev limiter, I went ahead and installed the stock weights in the kn and can now hit 38-39, does this sound right? I was under the impression that with the new variator and 6g weights it would be faster all around, should I put my stock variator back in with the 6 g weights? What weights should I run in the KN for a 235lb rider?
Please help
PostPosted: Mon Jan 07, 2008 3:39 pm
Just realized I posted this in the wrong forum, mods can you please move it for me?, thanks
PostPosted: Mon Jan 07, 2008 4:29 pm
Let the KN break in for another 20 miles.
Flickr photostream http://www.flickr.com/photos/sanjuro62/
One of my rides
Please do not PM me scooter technical questions. Use TR.
PostPosted: Mon Jan 07, 2008 4:38 pm
Should I run the 7.5 weights until its broken in then switch back to the 6g? I also got a set of 5.5 g rollers as well
PostPosted: Mon Jan 07, 2008 4:58 pm
Run with the 7.5 grams for break-in, and see if your performance improves. If it doesn't try the 6.0 gram rollers.
One of my rides
PostPosted: Mon Jan 07, 2008 6:29 pm
I just got some parts today from BSS and installed a mix of 5 and 5.5's and was not impressed in the hill climbing abilities I thought I was gonna gain. I gained a little off the line and it doesn't lag as much in the 18-22mph range as it did before. However this could be due to a couple other things as well... I noticed that the weights I had in there for the last 400 miles or so are ALREADY really well worn with serious flat spots. Also I installed the drop in filter from BSS at the same time so who knows maybe I need to rejet considering that it is FREEZING out and I have an aftermarket exhaust with the high flow filter and it runs a little rough till it gets warmed up.
06 Ruck **Lucky**
638
FrankiurRuckus wrote:
Get out of the game, cause this shit will make you eat ramen and starve your children bro.
PostPosted: Mon Jan 07, 2008 6:55 pm
One mod at a time my friends, at least in the performance category.
One of my rides
PostPosted: Mon Jan 07, 2008 10:30 pm
Well it ran fine all summer with the exhaust so all I really added was the filter and lighter weights because I figured that I could easily change the filter back out to the stock tomorrow or whenever easier than I could change the variator out. The cold really moist air really has seemed to affect it a lot so I'm not in a hurry to re jet it especially because it is hardly ever this cold for this long here.
06 Ruck **Lucky**
638
PostPosted: Mon Jan 07, 2008 10:57 pm
Words to live by...
bigluelok wrote:
4chan.org is your friend post his info theyll fuck with him
PostPosted: Mon Jan 07, 2008 11:03 pm
what needs to be broken in on the new variator?
PostPosted: Mon Jan 07, 2008 11:10 pm
The little triangular guides that are on the outer ramp plate face. Also, the smooth face of the variator itself is at a slightly different angle then the stocker, and the belt contacts it at a different angle on the edge.
One of my rides
PostPosted: Mon Jan 07, 2008 11:33 pm
Well I ended up just breaking down and ordering a Posh CDI, so now my question is, what is the recomended roller weight setup for an '05 ruck with KN variator and Posh CDI for a 6'2" 235lb rider? I tried searching, but I'm havin trouble finding a clear answer
PostPosted: Tue Jan 08, 2008 2:56 am
Give it time - Ruck engines, at least with the stock jetting, don't like the cold IMHO. I lose a lot of power below 30*F, and it barely even runs below 10*F.
Lil' Ruck, delivered 8/29/07, mileage as of 4/16/08: 3000
PostPosted: Tue Jan 08, 2008 11:43 am
i bought my KN and put it on at con and me and spacecoast went for a ride its the best mod ive done im useing the 5.5 and 6.0 grams i can truck up step hills at 35+
I'M ALL JACKED UP ON MOUTAIN DEW!
PostPosted: Tue Jan 08, 2008 3:17 pm
what is your top speed and how much do you weigh? What year is your ruck?
Rucksters browsing this forum: mrg7243, Rhythmic and 1 guest
