yer stress, few beers sorted it tho! Just wandering if liquid gasket can be used on the manifold? i wont be using the spacer ive seen someone had a custom spacer made to jack it up to the needed height but could it be used instead of paper?
Yes, also saw that custom spacer. Am sure you cound get that milled up in the UK. Seen the Japanese 2T guys using instant-gasket stuff. Used the orange type myself.
_________________ “Don't search for all the answers at once. A path is formed by laying one stone at a timeâ€
im sorry i dont know the engine had it when i bought it but bandaar is the man i bought her from he will know! i have a feeling its from tokyoparts but i could be wrong
to drill a hole in rubber and it be clean put the rubber piece in the freezer for about an hour and then drill it.
cool man thanks im not sure what im guna do with it yet but if i drill it i will freeze it first thanks! my mate surgested a, probably wrong spelling but, mylar drill bit any info if this is right? also he said slow and low that is the tempo to avoid melting
I love the case i came home a bit drunk and tripped over it the other day so now i know its fool proof, just needs some stickers or maybe painted yellow so i dont trip again!
It has been a while had a problem with webike not having the cylinder i want in stock and struggling to source one from other JDM shops so may have to go with another kit if it comes to it. Next one i like the look of is Autoboy 122cc LINK im trying to get a kit with cylinder and head as im not up for getting a stock head machined to the right CR id rather (not being lazy) have it done for me so i dont really cock things up!
Anyone had an Autoboy kit? Ive searched but come up short apart from their a small tuning company in japan with hand ported work etc. i dont mind the extra money for something done right if you know what i mean, they do a 100cc kit so you dont have to go big bore but if im putting this much in i thought i might aswell go balls to the walls
We thats enough text this arrived today with a Drowsports package on its way that just touched down in the UK so that will be up shortly, heres a pic and a tune if you like your wobble
OEM parts arrived, stator in and polished flywheel on! also got some stuff to remove the powdercoat good job on shock mount but weak on the frame, best send to pros to do this job i think
also tested some paint (and some stickers ) out for the gas tank cover, nice stuff flex and petrol resistant
removed powdercoat from engine hanger respray in progress. I liked the CVT paint job of a few rides that came out so something a bit different did the fan
thanks man, drowsports package will arrive today with goodies for dave!
later that day................
starts off with a the stage6 gearbox case does not fit the 100cc minarelli gearbox is slightly too long and the bolt holes dont line up on the top ah well worth a try only £45 for a new OEM one
then a the block off plates are sweeeeeet! and the OEM fan cover is like hens teeth in the UK dont think they were ever put on so adds a little more class! pics awayyyyyy!!!!!
since the stage6 didnt fit (but you will see it on another UK build) i decided to make the new one pop a bit loved the look on other rides, its more difficult i found out to make it look good tho + titanium nut in purple haze
seal coming tomorrow then get it on and test for leaks! JDM package coming this week with a funky new ................... wait and see
Rucksters browsing this forum: bumdo01 and 4 guests
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum
