Post new topic Reply to topic  [ 831 posts ]  Go to page Previous  1 ... 27, 28, 29, 30, 31, 32, 33 ... 56  Next
 Post subject: Re: (•) Ghost SF x Danko (PGM-FI Zoomer) DORF problem.
PostPosted: Tue Jun 19, 2012 2:19 am
Hey, thanks man!! Glad you like it and can see all the work that has been
put onto it! :highfive: Can't wait for it to be completed myself - it's been
too long. Yes, this bike was definitely going to stay as reliable as possible;
but let's be honest the life length probably has been slimmed down a bit
due to all under the hood mods. But what do I care! :banger:
I'd call it a curse, like Greg(MNNTHBX) I can't leave things that bug me alone,
haha.
Oh and about the DORF problem; this is nothing anyone should be worried
about since it's probably 1/1.000.000 probability to happen and it has not
happened anyone else! Greg offered to send me new pins without even
charging shipping.
I'm just hoping that new pins will fix it.
SSW TR-BUILD THREADS.
GRAPHIC WORK.
 Post subject: (•) Ghost SF x Danko (PGM-FI Zoomer) DORF problem.
PostPosted: Tue Jun 19, 2012 9:23 am
I have tried to search after a guide on how to install the Acewell gauge, but failed. Does anyone have a clue?
I have trouble to understand where to join the single yellow wire(rev meter).
Also I'm not sure if my speed sensor is correct...how should it look like?
GRAPHIC WORK.
PostPosted: Tue Jun 19, 2012 12:44 pm
Hey man,
The rev-meter lead goes to the coil. There may be a small "adapter" that allows you to "piggy-back" the spade connection on the coil, or the wire is wrapped around the lead going to the spark-plug. Wrap tight 6-7 times and tape up to secure, do the wraps by the coil.
Not sure what the speed sensor looks like, but should be a magnetic sensor which picks up the three small magnets that are dropped in the rotor-bolts. Any photos? Fitted an Acewell on another guy's Zoomer ages ago, worked ok in the end. Not sure where we got permanent and switched power from though??
Regards the indicator and hi/low beam lights etc you can trap the coloured wires from Acewell in the specific connector at cluster below the handlebars. These will then light-up on the Acewell dash.
Hope that helps.
“Don't search for all the answers at once. A path is formed by laying one stone at a time”
PostPosted: Wed Jun 20, 2012 2:19 am
Hey,
Thanks for your help and insight! I was wondering what that naked, kinda long wire with a little...
pill like thing in the middle was. I'm guessing it is the 'adapter' top piggy back the spade
connection on the coil, or that other solution you mentioned.
The speed sensor looks like this:
And I weren't sure what the other tiny spacers and another bolt which looked suspicious just lying in
a tiny sealed plastic bag.
Yesterday, I also got the indicators work for the turn signals - the problem was that I connected the
wires from the speedo into the + on the turn signals, they were supposed to be connected to. (-) aka.
ground. Weird, but true.
By accident I found this, which may well help out anyone else trying to install this sensor system.
http://www.acewell.co.uk/manuals/ace-s-fitting-instructions.pdf
I found out that the permanent power to only make the clock show when the bike isn't running is by
connecting it straight to the (+) on the battery. The switched power should be connected to one of the
two wires coming out of the key ignition assembly (or w/e it's called), in my case it was the red with a
green line in it.
What about the low fuel sensor? Do I HAVE to get one of those Metro fuel sending units, or can it work
just like the original one on the bike?
GRAPHIC WORK.
 Post subject: Re: (•) Ghost SF x Danko (PGM-FI Zoomer) To wire the Acewell.
PostPosted: Wed Jun 20, 2012 4:57 am
Hi,
Yes the item in the photo is to be attached to forks, near the brake caliper. Set close to the rotor bolts to pick up the magnets (inserted in rotor bolt heads) as they spin/pass by. Then set-up wheel circumference and the option for three magnets on the meter.
You do not fit Met sender (you have FI tank, so it will not fit). If you have removed the stock water/fuel lights then maybe find the connections for both and chose a suitable light on Acewell. Same for FI start-up light that was on stock speedo.
PostPosted: Wed Jun 20, 2012 2:25 pm
Damn this get looks awesome! great job on the frame tuck! :banger:
LoS x Standard Functions
SSF2 Kaiju Build
=> losgarage blog <=
PostPosted: Wed Jun 20, 2012 3:22 pm
bandaar wrote:
Hi,
Awesome, thanks! Although I really think it's a huge bummer that the Met sender won't work on a FI Zoomer. Do you have any idea if the FI lamp will constantly stay on if you have plugged out one of the connectors near the actual FI-assembly on the motor?
Thanksss! But I still feel I could have done it much better, firsts are seldom perfect. Thanks for
helping me out with some stuff! :wanker: :highfive:
Been on a prowl - looking for 8mm lug nuts, guess what? There isn't any. Although I found these
oversized nuts in the same gold as my ATR rear shock! Now to just get myself some studs and put
them on my rear wheel.
Got most of the indicators working now - Only 2 things left and they are probably a lot easier than
I think.
Tried on my chin bone and it looks great. can't wait to see it from the side. Also fixed my DORF seat
frame and it's even sturdier now. Some write up on how I did it will be here later.
GRAPHIC WORK.
PostPosted: Thu Jun 21, 2012 2:59 am
with each pic it looks better and better!
H-D is a shortcut for HonDa!
Project Choppster: http://totalruckus.com/phpBB3/viewtopic.php?f=93&t=48350
PostPosted: Fri Jun 22, 2012 1:36 am
love your bike, definitely an inspiration.
PostPosted: Fri Jun 22, 2012 1:53 am
:wc_flag: your ruckus is too CLEAN.
build thread ------>http://totalruckus.com/phpBB3/viewtopic.php?f=93&t=70981
PostPosted: Fri Jun 22, 2012 7:28 am
looks good man. keep it up
2009 GET-Retired
PostPosted: Sat Jun 23, 2012 11:19 am
Thanks a lot!
You're too kind. :highfive:
So SUE ME!! :pissed: Just kidding, thank you! :wanker:
Right back at ya! :highfive:
GRAPHIC WORK.
PostPosted: Sat Jun 23, 2012 6:38 pm
Nice signal placement :)
2t build
4t build
drowsports
standardfunctions
RUCKAHOLIC!
PostPosted: Tue Jun 26, 2012 4:00 am
Thanks! :) :wanker:
Having big problems with the exhaust progress. I know that I want
something that has to be quiet and that points out a little to the right
to compensate for the left side throttle body and all that. I have done
some mock up's but I'm not sure if I'm ready to show any...very very
difficult decision.
Any easily browsable sites with exhaust's?
Ordered the NAD.Guard v2.0 from Justforrucks and uh, it's a 3 week wait for it to come in.
Not going to use the fuel sensor on the Acewell since apparently the EU Zoomer can't fit a
Metro fuel sending unit into it. Sucks. Going to use the original lights and do my own bracket.
GRAPHIC WORK.
PostPosted: Tue Jun 26, 2012 10:01 pm
Who says a metro sender can't fit? You've done tons of custom mods so far why not try one more?
i like fast rucks, and faster women
Alice
Rucksters browsing this forum: 2point0vtec and 3 guests
