Post new topic Reply to topic  [ 4 posts ]
 Post subject: rear facing to front facing carb probs?
PostPosted: Tue Jun 12, 2012 4:49 pm
I was running a rear facing TM28 on my slightly modded 150 with no problems. I went fatty and have to run my carb forward facing and now it cuts out at 3/4 to full throttle but runs great down low.... MY temp sensor gave out on me so I no longer have acces to the cylinder head temp, any ideas??? plug is not white but still a good dark brown?
How to Make A Ruckus
 Post subject: Re: rear facing to front facing carb probs?
PostPosted: Wed Jun 13, 2012 7:27 pm
is the carb level? If the carb is pitched up, the fuel level in the bowl can starve the carb under load. I solved my issue with Composimo's angled clocking flange. Make sure your fuel pump is secure and has a good vac source too.
-'08 Honda 125cc GY6 Ruckus
PostPosted: Thu Jun 14, 2012 4:51 pm
I have already ordered the clocking/adjusting mount just waiting on composimo to get opened back up!!! It is way off
PostPosted: Fri Jun 15, 2012 8:47 pm
I have a feeling that will solve your problem.
Rucksters browsing this forum: No rucksters and 8 guests
