Post new topic Reply to topic  [ 18 posts ]  Go to page 1, 2  Next
 Post subject: MPAB Foot Brace is back in stock! 8/10/12!
PostPosted: Thu Aug 11, 2011 1:19 pm
Just ordered mine! :D Thanks Minkus!
HERE : http://standardfunctions.com/store/index.php/mpab-foot-brace.html
 Post subject: Re: MPAB Foot Brace is back in stock!
PostPosted: Wed Sep 14, 2011 11:12 am
:wanker:
FATPHOSxMINKUS
http://www.STANDARDFUNCTIONS.com
http://twitter.com/STDFNCTNS join us!
http://vimeo.com/3065290
INSTAGRAM : @standardfunctions
anti-cookie cutter x Kiwi2racing
hi haters :wavehello
PostPosted: Fri Nov 18, 2011 4:34 pm
My MPAB brace came yesterday, love it! :banger: I noticed there were pre drilled holes for pegs, but I did not see them on your website. Do you sell pegs seperately? I'd like to order a pair if possible, let me know thanks!
Part-Time Amateur Rookie.....On The Side
My Ruck
viewtopic.php?f=95&t=65204
PostPosted: Wed Dec 28, 2011 6:02 pm
i would like to know the same on the pegs thanks...
MY build:http://totalruckus.com/phpBB3/viewtopic.php?f=93&t=63297
PostPosted: Sun Jan 08, 2012 10:44 pm
They dont have pegs seperately. I was able to get some NCY ones from the used part section. Keep checking, they show up, but go fast.
My Ruck
PostPosted: Mon Jan 09, 2012 6:55 am
Pics
Natron's Ruckus
SHORT BUS CREW
PostPosted: Tue Jan 10, 2012 4:42 pm
Pics of the pegs. Had to make something to keep the pegs from sagging though, easy enough. I heated and bent the carbon fiber and it messed up the outer layer, but it's not visible when mounted. The NCY brace is threaded for adjusting bolts, the MPAB is not.
My Ruck
PostPosted: Tue Jan 10, 2012 4:44 pm
dang i want some looks good...
PostPosted: Tue Jan 10, 2012 5:09 pm
Thanks, it took a while to find the pegs, but it's sooo worth it.
My Ruck
PostPosted: Thu May 10, 2012 10:12 am
Do you still have them in stock? I cant see them on the website
cheers :wanker:
 Post subject: Re: MPAB Foot Brace is back in stock! 8/10/12!
PostPosted: Fri Aug 10, 2012 1:02 pm
RESTOCKED :banger:
FATPHOSxMINKUS
PostPosted: Mon Aug 20, 2012 1:53 pm
Ordered! :banger:
MMRC
My ride: viewtopic.php?f=96&t=50571
GORBY GEAR/RUCKUS NATION PRODUCTS: http://gorbygear.bigcartel.com/
PostPosted: Mon Aug 20, 2012 1:57 pm
Should of drilled the holes the other way...
Then you would not need to find NCY pegs then find a way for them not to droooop.
:dubious: :ucrazy:
Conway!!!
If you don't see Localism then where your at sucks!!!
viewtopic.php?f=94&t=63314
PostPosted: Mon Aug 27, 2012 1:53 pm
Just remembered this product.
http://passwordjdm.com/PasswordJDM-Ruck ... 3C409.aspx
Expensive for just brackets but you can run some cheap pegs and they wont droop!!!
Conway!!!
PostPosted: Thu Sep 06, 2012 11:32 am
Yup...no droop using the PWJDM brackets and pegs...had to GET some longer stainless bolts to mount it, and put 1/2" long nylon spacers in the floorboard bolt "pockets" so the bar didn't "dip" when i tightened everything up. Also had to get shorter set screws...the ones that come with the PWJDM pegs were too long. Got everything at the local hardware store for less than $10. Love it...Thanks SF :banger:
MMRC
Rucksters browsing this forum: minkus and 0 guests
