Post new topic Reply to topic  [ 139 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9, 10  Next
 Post subject: Re: The White Bomber build! Needs help! with harness!
PostPosted: Tue Feb 14, 2012 4:54 pm
Crazy fuckin tail.
viewtopic.php?f=95&t=65664 Godzilla
viewtopic.php?f=95&t=76464 Russian Roulette
PostPosted: Tue Mar 20, 2012 7:00 pm
scooped up a new wheel Image One of the bolts wont go in because the alighment is off a little. I'm thinking of dremeling it to make the hole a little bigger. If anyone thinks this is a bad idea let me know please. I feel like what ever i buy doesnt fit right... Spending too much money on this stupid thing. Wish i just bought a bike now...
viewtopic.php?f=96&t=53998
PostPosted: Tue Mar 20, 2012 7:10 pm
i would try taking all bolts out and screwing that one on first... maybe try spinning the hub to line up to different holes?
just trying to keep you from taking a dremel to that nice wheel.
viewtopic.php?f=93&t=61225
^ Lady Trouble ^
viewtopic.php?f=93&t=67102
^ Ground up build ^
http://www.facebook.com/ScgCreations
^^^Support those that support the scene!^^^
PostPosted: Tue Mar 20, 2012 7:15 pm
Def rotate the hub first before drilling anything. I've seen the same thing before. Rotating the hub fixed the issue.
Ruck1Built - Complete Honda Ruckus Fabrication
#LRC
PostPosted: Wed Jul 11, 2012 9:01 am
Alright I'm bringing my ruck to someone to finish my ruckus, I noticed there is a leak from my motor but not sure where. I think all the oil leaked out cuz I checked the stick n nothing on it. Still waiting for poon to send me my 260mm rotor with rrgs brake kit. Got my front wheel powder coated, hopefully I can get this thing on the road soon. I want to install hid kit or a Trailtech light but I'm scared it won't pass inspection any comments?
PostPosted: Wed Jul 11, 2012 9:32 am
if your worried about it, i would just keep the headlights stock and install the aftermarket setup after it gets inspected. it would make everything easier in my opinion...
^ Lady Trouble ^
^ Ground up build ^
PostPosted: Wed Jul 11, 2012 10:10 am
On The wheel, if rotating don't work, try barely screwing all of them in to begin with. Instead of tightening the others down then trying to put that one in.
-Stephen
•MONSTERGY6 loyal•
Instagram @SBREWER89
•My ruck- The Addiction viewtopic.php?f=95&t=71318&p=1235621#p1235621
•For Sale Thread - viewtopic.php?f=9&t=74450
•Upper Class White Trash•
PostPosted: Wed Jul 11, 2012 7:43 pm
I took a Dremel to it and the wheel fits now, yea I was thinking about installing after inspection.
 Post subject: Re: The White Bomber build! 260mm setup
PostPosted: Sat Jul 21, 2012 5:55 am
help?
 Post subject: Re: The White Bomber build! 260mm setup 95% complete
PostPosted: Sat Jul 21, 2012 6:05 am
He might just have forgotten.
Also, if you are missing spacers...try a hardware store,
maybe they'll have stainless spacers in different sizes.
This will save you time.
SSW TR-BUILD THREADS.
GRAPHIC WORK.
PostPosted: Sat Jul 21, 2012 6:22 am
i asked the same question on his thread but he said it could be my wheel spacers, but the spacers i have on centers the wheel perfectly
PostPosted: Tue Jul 31, 2012 5:55 am
:suicide: sometimes i just want to pour gas on it and throw a match, but you gotta keeep it up. the bike looks sick.
Frankenstein - GY6MetRuck
UnderConstruction
StuntMet
PostPosted: Sat Aug 04, 2012 9:56 pm
i just wired up the dan max harness, could not get it fired up today. It won;t turn over, i checked the spark plug and i tested for spark so no spark, changed in a new spark plug, it made two fire noises in the exhaust like it was going to turn over. but nothing happened. I let it cool down so i dont kill the starter or battery. Tried it later again and now nothing cranks. Im not sure if i fried the starter or stator. But when i click the starter button it makes a clicking noise. The starter relay is hot so im not sure whats the deal. I am running a vaccum pump also. Some people told me to spray starter fluid in the carb, but some say its a bad idea. Whats your take on this? I primed the fuel line to the top of the carb by sucking and blowing on the vac line. Also when i hit the starter button it kinda sometimes just cranks for a second, so i gotta keep clicking untill it cranks constantly, maybe its a bad ground. Do you know how i can check if its the stator problem or starter relay that got fried? I also ordered a ac voltage regulator, How do i wire this thing up? Another thing is my tail light led wont light up when i press the brakes, the led turn signals blink also with the flasher relay that came with it. I put in the custom flasher relay caled elfr-1 but it doesnt make the signals blink.
 Post subject: Re: The White Bomber build engine wont turn over?
PostPosted: Sat Aug 04, 2012 11:36 pm
If you go to turn it over and it makes a clicking noise your battery is dead....also put on the stock cvt cover and kickstart and try that
TRICLOPS
viewtopic.php?f=95&t=56682&p=943034#p943034
Godzirra
viewtopic.php?f=95&t=57768
10x10 zuma swap
viewtopic.php?f=96&t=78354
PostPosted: Sun Aug 05, 2012 12:56 am
Don't think it's the battery, I had a meter and it's a 12 cell and t puts out 13,
