Post new topic Reply to topic  [ 41 posts ]  Go to page 1, 2, 3  Next
 Post subject: Rowdy riva...updated and pics of my fish tank
PostPosted: Fri Feb 18, 2011 3:24 pm
started as a parts scoot on the side, then turned into true love
not much done other then taken apart. i just ordered a new carb for it and some rollers to pep up the motor. then once it is running its out of the garage and to the shop!
one rule for the build, it has to be low or it doesnt count :banger:
just mocking up the goofy single sided front fork to see how low that gets and thinking about a body drop
ok so started doing a little to it the other day, ive been super busy with other side work but its a little lower now.
still needs alot more but i need to raise to entire motor or the motor angle will be shitty
ATR rear shock cut lower perch and welded new tabs to mount to the riva motor
By knoobz at 2011-10-02
Before:
After:
2/9/12
Ok I gotta get it ready for spring so here we go
One off 12" stretch, made it bolt in so if needed I can go longer in the future or offset for fatty
2/9/12
Started on a center mount shock so once the plastic are on it won't be seen....
Just having a blast with this build I can't wait to ride it!
2/10
Got some more work done on the center shock mount may need a gusset not too sure yet
2/13
Ok center mount ... May need to mess with the engine angle but ill wait and see if I get a oil pressure light
Bitch is dusty lol
2/22
Relocated my carb and nodded my fenders to fit ... Sort of...also made a quick handle bar
actually starting to look like a scooter again!
i see my air filter
flipped intake tube cut and extended
handle bars
2/28
Have not updated in a few days but def been busy. Made new fuel tank and mounted controls to my handle bars. Also mounted front shock!
Bars mounted
So close to just bolting on
There we go!
Center rear shock is now in the way of my fuel tank so to make room I chopped out the battery and brackets to make room for my new tank
Able to reuse stock level sensor and vac. Operated petcock
All stainless and don't mind ghetto cap I still need to order one
Fuel tank just clears the underside of my seat
a clean scoot is a happy scoot!
Riva Ruck Build
My Rowdy Riva Build
 Post subject: Re: one rowdy riva
PostPosted: Fri Feb 18, 2011 3:35 pm
:popcorn: low :banger:
my 03 ruckreation
viewtopic.php?f=93&t=52703&hilit=03ruckreation
PostPosted: Fri Feb 18, 2011 5:14 pm
:banger: already looks DOPE... lol
Mole's Ranfla :Vino Classic viewtopic.php?f=94&t=50434
2 > 4
Us.Vs.You.
PostPosted: Fri Feb 18, 2011 8:26 pm
o ya the scooter has a full body so i wanna slam it and stretch it so the rear fender is pushed farther out, and maybe have some of the rear shock hanging out too.
then since i got hit on my ruckus and it totaled i wanna paint it white with teal accents since my ruckus was tahiti green
R.I.P
Shot at 2009-10-01
Shot at 2009-10-01
in her prime
Shot at 2009-08-09
Riva Ruck Build
My Rowdy Riva Build
2010 King of HATE
2010 King of HATE
PostPosted: Sun Feb 20, 2011 5:35 pm
waiting in eager anticipation
twitter.com/mertechperf
'08 Ruck "Fresh ta deaf"
'10 Elite 110 "Ghetto Blaster"
'98 Superhawk "Trouble"
'74 CB550 Restomod
MANdown
PostPosted: Tue Feb 22, 2011 8:42 am
so am i im! I'm waiting for my carb so i can start it up and im talking to a buddy with an edm so he can respline me a daytona hub for the ruckus, so i can run those 5 spoke polished rims on the riva
o ya :banger:
Riva Ruck Build
My Rowdy Riva Build
PostPosted: Tue Feb 22, 2011 8:44 am
woohhoo!!! anxiously watching!
Cookie
viewtopic.php?f=92&t=45567
PostPosted: Wed Mar 16, 2011 3:53 pm
Fuckin scoot won't start has spark Orange blue color decent compression 120 ish and I'm misting gas into the intake. I'm just about stumped it wont even stumble when I'm trying to start it.
Riva Ruck Build
My Rowdy Riva Build
PostPosted: Wed Mar 16, 2011 6:39 pm
You have He motor apart enough to mess up the timing?
Hoodride-http://totalruckus.com/phpBB3/viewtopic.php?f=92&t=50254
GY6 Exhaust flanges-http://totalruckus.com/phpBB3/viewtopic.php?f=47&t=62968
2010 King of HATE
2010 King of HATE
PostPosted: Wed Mar 16, 2011 11:27 pm
maybe just do cosmetic updates for now? lol
'74 CB550 Restomod
MANdown
PostPosted: Thu Mar 17, 2011 7:41 am
haha i need to get it to my work first then the fun begins...
im going to steal the spark plug wire and coil from the other motor and swap it to this one. it has to be losing spark cause the bike waste fires so everytime the cylinder is at tdc the spark plug fires it should at least back fire on me
Riva Ruck Build
My Rowdy Riva Build
PostPosted: Tue Mar 22, 2011 8:12 pm
May just be getting another Riva this weekend this whole putting three bad engines together to make one good one just isn't working out :dubious: :dubious:
Riva Ruck Build
My Rowdy Riva Build
PostPosted: Thu Jun 02, 2011 2:59 pm
And so it begins .... finally :lol:
So plans are
6 inch stretch
Move seat back 6 inches and re shape cushion
Go lower
New carb
New exhaust
Angle handle bars down cafe racer style
Relocate battery
I'm sure more things will get added but that's the start
Riva Ruck Build
My Rowdy Riva Build
PostPosted: Sun Oct 02, 2011 8:58 pm
updated first post with ATR shock installed
Riva Ruck Build
My Rowdy Riva Build
 Post subject: Re: one rowdy riva, ATR shock installed
PostPosted: Sat Oct 08, 2011 2:23 pm
ok so did some mock-up what do you think ... im diggin it :banger:
Riva Ruck Build
My Rowdy Riva Build
