jcrabb13
  Posts: 4365 Location: College Station, TX Gender:
Post subject: Re: jCrabb's "People's Champ" -- back to black wheels! Posted: Tue Apr 24, 2012 8:15 pm |
dooder wrote: Werd thanks problem wont bother then i feel ya, i just really didn't like the untouched metal on the front, this will hold up for now.
BaconLiar wrote: Front frame can go to hell. Po' Ass | People's Champ | StatusScoots
| Top |
5prock3t
  Posts: 2986 Location: Florida Gender:
Post subject: Re: jCrabb's "People's Champ" -- back to black wheels! Posted: Wed Apr 25, 2012 4:54 am |
jcrabb13 wrote: dooder wrote: U ended up using plastidip?? How's it hold up?? Was thinking on using it quick fast on my second building just to get it up and running for the summer? Then powder next winter.
How many cans u use? it's definitely VERY fragile/sensitive. but it was 6/can and i only used one can (not even the whole thing) so it's expected, plus you can peel it right off whenever you need to. i plan on doing something more permanent whenever my tires get low. a coat of spray on clear might help it hold up?  jcrabb13 wrote: Tz_Swagzilla wrote: I say do the front frame. I'd like to see a gas cap on this thing too quit slacking!
i don't think plastidip would hold up on the frame...that will come in time, like i said i plan on painting by the end of the year. the summer if i do well tell Composimo to answer his PMs, gas cap is on my order list for him! Ive painted my front frame with it a couple of months ago, IMO, its only sensitive or fragile while youre painting with it and its uncured...mine is holding up nicely without a blem. Id even go as far as to recommend it to any and everybody...Imma keep a can of this on hand for multiple uses! And besides...if youre second guessing the idea, it peels right off if you fail or change your mind. Youre only out $6-$10 for the can. To me it looks like you either got too close or too hasty...you may have even tried to fix some kind of debris issue. I had a small issue like that, where I tried to fix it, it began to spiral out of control, but then I just started spraying more and from further away until it leveled out.
_________________ 5prock3t'5 09 RED Ruckus ...I drive in a lawnmower, beep, beep, beep, beep
| Top |
jcrabb13
Post subject: Re: jCrabb's "People's Champ" -- back to black wheels! Posted: Wed Apr 25, 2012 10:23 am |
5prock3t wrote: you may have even tried to fix some kind of debris issue. you sir, are a psychic. i'm trying the light layering now, if that doesn't work, i'll just pull it off and start over. i'm impatient, how long did you wait on it to cure? if i do it again i'll wait for a day when i have more time and don't have to work at 6. lol famicomdisk wrote: jcrabb13 wrote: tell Composimo to answer his PMs This. How long have you waited? i sent it earlier this month while he was in North Carolina or wherever honda day was.
| Top |
5prock3t
Post subject: Re: jCrabb's "People's Champ" -- back to black wheels! Posted: Wed Apr 25, 2012 10:34 am |
jcrabb13 wrote: 5prock3t wrote: you may have even tried to fix some kind of debris issue. you sir, are a psychic. i'm trying the light layering now, if that doesn't work, i'll just pull it off and start over. i'm impatient, how long did you wait on it to cure? if i do it again i'll wait for a day when i have more time and don't have to work at 6. lol See if you can cut out around it, if you pull its gonna spiral out of control, I used the back of a razor blade(carefully) but I wsnt doing this over a BADASS wheel either. I sprayed mine after work, waited like 3 hours and reassembled it...Im pretty sure I went for a test ride, but by the next day it was 100%...after a few days I gave up on the idea it was fragile or delicate. Do the frame, do the frame, do the frame!!!
| Top |
jcrabb13
Post subject: Re: jCrabb's "People's Champ" -- back to black wheels! Posted: Wed Apr 25, 2012 12:50 pm |
5prock3t wrote: Do the frame, do the frame, do the frame!!! no, no, no. all in good time sir, you of all people should appreciate stock
| Top |
5prock3t
Post subject: Re: jCrabb's "People's Champ" -- back to black wheels! Posted: Wed Apr 25, 2012 1:09 pm |
jcrabb13 wrote: 5prock3t wrote: Do the frame, do the frame, do the frame!!! no, no, no. all in good time sir, you of all people should appreciate stock  You flipped the switch on all that long ago.
| Top |
TT-350z
   Posts: 8031 Location: Frisco TX Gender:
Post subject: Re: jCrabb's "People's Champ" -- back to black wheels! Posted: Sat Apr 28, 2012 7:26 am |
im pretty sure thats on the pegs not the kickstand lol
_________________ MY RUCK
raven125 wrote: MADE IN CRAP!
penguins420 wrote: hey can i suck your slurp.
| Top |
jcrabb13
Post subject: Re: jCrabb's "People's Champ" -- back to black wheels! Posted: Sat Apr 28, 2012 8:17 am |
lanemeyer14 wrote: TT-350z wrote: im pretty sure thats on the pegs not the kickstand lol Well shit....that's what my ruck looks like on the kickstand naa the FLP kickstand has it standing much straighter up, and mines shorter than the rest (excluding Ho's)
| Top |
