Post new topic Reply to topic  [ 8 posts ]
 Post subject: rear wheel question
PostPosted: Sat May 12, 2012 5:45 pm
Will a ruckus wheel fint underneath a metropolitan? My rear wheel is bent somewhere and walks around a bit. I havent seen alot of rear wheels for metros listed but Ruckus ones seem quite frequent. If its a will work with mod i.e. remove inner fender etc thats fine too. thanks for the info
Dale
 Post subject: Re: rear wheel question
PostPosted: Sat May 12, 2012 6:57 pm
DIO wheel will fit the metro.
Dont
Forget
Intelagence
EL BURRO
http://totalruckus.com/phpBB3/viewtopic.php?f=92&t=66106
MONSTER GY BUILD
http://totalruckus.com/phpBB3/viewtopic.php?f=92&t=81125
PostPosted: Sat May 12, 2012 7:06 pm
Don't think the Ruckus wheel would work without the ruck swingarm. I'm pretty sure the ruck wheel is .5 wider? I know you can't go much bigger than the stock 90/90/10 tire because it won't clear the engine casing with the Metro swingarm.
My Met Build
Shooting Star viewtopic.php?f=92&t=50500
"Never run out of real estate, traction and ideas at the same time." - Mario Andretti
PostPosted: Sat May 12, 2012 9:37 pm
the ruckus rim is offset from the met swingarm will be off center by about 1.5 inch i have dio met and ruck rims if you need . Dont think it will clear met shock since its mounted on the transmission case instead of the swingarm ,will be off center toward the shock and wider.
with ruckus swingarm u need to use ruck rim not the met rim tire will not be centered it will be offset about 1.5 inch away from shock.
http://i112.photobucket.com/albums/n188 ... kus033.jpg
PostPosted: Sun May 13, 2012 3:26 pm
Tire is going to be too big for the met swingarm. Might as well do a ruck swing while you're at it.
Follow Me! @MetricGretchen
And on this day, not a single fuck was given.
PostPosted: Mon May 14, 2012 5:37 pm
And here begins your slide down the slippery slope.
PostPosted: Mon May 14, 2012 8:22 pm
no he got nice rim and stock tire
PostPosted: Tue May 15, 2012 6:33 pm
quoted for mothafuckn truth.
I first wanted a ruck swing arm... Then a stretch. A week later my bike was laying in shambles, in surgery over at TT-350z's house getting an ass transplant. Hours later a mild mannered metropolitan became "Gretchen, the metuckus"
