 Post subject: Need a few torque specs please..
PostPosted: Mon Apr 30, 2012 7:12 am
I recently bought a 05 Met thats lead a rather hard life and I havent had the extra bank to order a service manual for it(too busy buying parts to get it running). I was hopeing someone could be kind enough to list a few torque specs for me. I think I am going to have to pull the rear wheel since its not contacting the road properly. So will need the torque spec for the rear wheel, front wheel would be good to have as well since I hate to tighten those to about Ugh.If its not a wheel bearing then I will need the torque for the swing arm bolt. Also need the torque spec for the exhaust header. probably around 10 ftlb. And the steering stem nut since the handle bars seem a bit floppy. The only other one I think I may need is the head bolts since the guy I bought it from cross threaded the spark plug so I may have to remove the head and retap the hole or put in a heli coil at some point. Sorry its kind of a long list and worse to I will guess from the common service manual. Thanks in advance
Dale
 Post subject: Re: Need a few torque specs please..
PostPosted: Mon Apr 30, 2012 10:11 am
rear lug nut 87 ft lb
front axle nut 33 ft lb
steering head nut 51 ft lb
head bolts 9 ft lb
I'll get the rest later.
PostPosted: Mon Apr 30, 2012 3:04 pm
Thanks much I really appriciate it!
Dale
PostPosted: Tue May 08, 2012 6:25 am
had to get into the flywheel as well if you could post that one im figureing 25ft lb
Dale
Patron Saint of TR
Patron Saint of TR
PostPosted: Tue May 08, 2012 6:31 am
Here's a link to the service manual info..... viewtopic.php?f=13&t=58894&hilit=service+manual
The "Addiction"
SSBC: Under Compensating Daily Since 2008
TT-350z wrote:
thats like me rocking ssbc stickers without meeting stimpy :twisted:
PostPosted: Tue May 08, 2012 2:27 pm
thanks much looked all over hell for a downloadable manual for the metro no clue why I never though to look for a ruckus one
Rucksters browsing this forum: RuCk1t, shotnva777 and 1 guest
