Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3  Next
 Post subject: CB Met w GY6 build
PostPosted: Thu Mar 01, 2012 5:40 pm
I was fortunate to pick up this met for 500 back in November
It ran well as stock but was def in need of aesthetic repair and a bigger engine :lol:
As it sits, May 2012
I am in the final stage of my build but id like to post some pictures of my progress.
The first night in my garage
Not too long after, this met is stripped
Plastics removed, fresh paint
A good start, :)
SS 29 april :banger:
2005 Met Build w GY6
http://totalruckus.com/phpBB3/viewtopic.php?f=4&t=66544
I am enjoying my day. Are YOU?
 Post subject: Re: CB Met w GY6 build
PostPosted: Thu Mar 01, 2012 5:57 pm
Killer mount! :highfive:
My Scoot.
viewtopic.php?f=95&t=37866
PostPosted: Thu Mar 01, 2012 7:11 pm
Will you take a picture of the mount from the top/above? Im curious as to how you got that to fit. I had to use a PWJDM one for my swap
My GY6 Met Build Yoshi
PostPosted: Fri Mar 02, 2012 10:54 am
Trent, I got a lot of pointers from your build thread, appreciate it
Here are a couple shots
Bust out the grinder and get busy
If anything, you just have to bend the bottom left ear a little bit til it touches the crossframe, then drill the holes
PostPosted: Fri Mar 02, 2012 11:02 am
The extension the killer mount gave created a useless top shock location, so fab was required
This is the work done at SF
Trust
At 6' need a little leg room, these pegs should help
BTW, the PWJDM pegs and kickstand fit perfectly, the body panels fit cleanly over it, except the bottom splash guard,
PostPosted: Fri Mar 02, 2012 6:36 pm
NICE!
chitownruckus.com
swaptchicago.com - store OPEN!
instagram : swaptchicago
PostPosted: Fri Mar 02, 2012 8:29 pm
Very nice indeed! Clean work on the motor and shock mounts. I'm interested to see how it all looks put together with the bodywork. :banger:
My Met Build
Shooting Star viewtopic.php?f=92&t=50500
PostPosted: Sun Mar 04, 2012 5:11 pm
The under seat storage is going to have tp be completely cut up right?
08 Metro- 60/50 club :banger:
viewtopic.php?f=92&t=63326
09 Metruck
viewtopic.php?f=92&t=79193
ConElite wrote:
You should not have to sacrifice ANY top end for Acceleration with a properly tuned CVT.
PostPosted: Thu Mar 08, 2012 6:29 pm
Ran for the first time the other night.
Great feeling
TwoBros exhaust
Updated Pics tomoro
PostPosted: Fri Mar 09, 2012 7:23 pm
Today was a successful friday for the most part :D
Tucked the atr harness and accessories
Repainted plastics and gloss, lots of wetsanding today. :pissed:
Still working on my tail light mount
the camera was on a bad setting for a bit
The last thing to do is bleed the brakes. so everything is coming off again so i dont spill on the plastics
PostPosted: Fri Mar 09, 2012 7:25 pm
It does, but i will make something to fit over the holes
PostPosted: Wed Mar 21, 2012 4:44 pm
Picked up a gs variator, 12 grams better than 14, :)
and new slow jets for the keihin pe24
the slow jet that was in the carb was a 55!! :shock:
I started with a 45 yesterday, runs better, but another drop in will clear it up
i think it can drop to 40, possibly 38, because its still running rich, it is only 150cc, no bb.
Riding in this SoCal weather is always tits. :D
Todo List
Wire acewell gauge and met sending unit, just waiting to purchase a ruckus resistor, mets dont have them.
Mount acewell speedometer magnet and pickup, wont fit on the front, found a spot on the back.
Finished pics soon
CB
PostPosted: Thu Mar 22, 2012 4:45 pm
You could Fiberglass the under seat storage area inside, and then plasti Dip it. If done right, I'm sure you could make it look pretty OEM.
Follow Me! @MetricGretchen
And on this day, not a single fuck was given.
PostPosted: Wed Mar 28, 2012 3:01 pm
So whats up with calling a pilot jet a "slow" jet?
See that a lot on this forum.
http://twobrothersgarage.blogspot.com/
PostPosted: Fri Mar 30, 2012 12:07 am
There are many articles and websites that use those terms interchangeably.
Another term for it is idle jet. Just matters on preference
