 Post subject: Anyone mess with an 01 Reflex flywheel before?
PostPosted: Mon Oct 10, 2011 6:16 pm
I have measured the threads on the flywheel to get a puller but the caliper reads right on 29.50mm So is it a 29 or 30mm tool? Hopefully someone has taken one off before.
OttoFactory Build Thread
OttoFactory Sale Thread
 Post subject: Re: Anyone mess with an 01 Reflex flywheel before?
PostPosted: Thu Oct 13, 2011 9:51 pm
I know mojo has had a couple of these, and I think one motor in the garage you may want to ask him. When I had one I thought it was a 30 but I can't be sure, if you look on a parts diagram like ronayers.com er something they often times call out the nuts and bolts there for measurements.
Mojitokus
http://totalruckus.com/phpBB3/viewtopic.php?t=24627
Metroelite
http://totalruckus.com/phpBB3/viewtopic.php?f=4&t=56385
PostPosted: Thu Oct 13, 2011 10:32 pm
Yeah I checked with no luck. Only thing that has me leaning twords the 30 is the 29 seems non existent.
PostPosted: Sat Oct 15, 2011 7:12 pm
Depending on the manufacturing tolerances and how used it is, I could see a precise caliper measuring a 30mm nut coming in at 29.5mm
Mojitokus
Metroelite
PostPosted: Mon Oct 31, 2011 5:18 pm
Ok ill let you know if it works, just got the 30x1.5 puller tool today.
edit: it works. That is the correct thread size for the 01 reflex flywheel.
