 Post subject: No electrical power!
PostPosted: Thu May 31, 2012 9:30 am
Hey guys so i accidently pulled out my brake lever wires connected to the brakes lever on the left hand side and i reinstalled it but now my brake lights, turn signals, the turn signal indicator, also the electric starter doesnt work.... My head lights work and the kickstart starts it right up! Speedo seems fine! Thinking it could be i fried something but not to sure. If anyone can help me that would be awesome! Hopefully its an easy fix
 Post subject: Re: No electrical power!
PostPosted: Thu May 31, 2012 9:34 am
Take off your battery box and unplug the switch that goes to that lever. then check your fuses, i'm sure thats all it is. but if you dont unplug that switch then i imagine that your just going to blow it again. then check and make sure you didn't short out the wires in that switch.
My builds:
Red Rocket
http://totalruckus.com/phpBB3/viewtopic.php?f=95&t=64397
Peacock
http://totalruckus.com/phpBB3/viewtopic.php?f=95&t=64397&p=1089566#p1089566
MET MAGIC
http://totalruckus.com/phpBB3/viewtopic.php?f=94&t=65346
fuse
MY RUCK
raven125 wrote:
MADE IN CRAP!
penguins420 wrote:
hey can i suck your slurp.
PostPosted: Thu May 31, 2012 2:03 pm
Okay ill try that just tryd the horn and that also isnt working! Im guessing all those things are connected to the same fuse or whatever
PostPosted: Thu May 31, 2012 2:14 pm
fuse for sure. If the cables from the rear brake sensor touched it each other when you threw them out, it blew the fuse. Thats it.
H-D is a shortcut for HonDa!
Project Choppster: http://totalruckus.com/phpBB3/viewtopic.php?f=93&t=48350
PostPosted: Thu May 31, 2012 2:26 pm
Sorry newb here wheres the fuse box can someone show me a picture of what i need to take off or replace
PostPosted: Thu May 31, 2012 2:39 pm
I don't have a pic of it, but it's right on top of the positive side of the battery. You'll have to take off a plastic cover to see the fuses. Good luck!
Rufus the Ruckus
http://totalruckus.com/phpBB3/viewtopic.php?f=95&t=65104
Buyer/Seller Feedback
http://totalruckus.com/phpBB3/viewtopic.php?f=86&t=72217
PostPosted: Thu May 31, 2012 2:45 pm
http://www.djnitro.com/forumcrap/Ruckus ... chable.pdf
Spend a little time with the service manual you can search for fuse
See if this helps you.
http://www.google.com/search?q=auto+fus ... 24&bih=644
Thanks Honda GET going
My 2005 :LR:
Total Ruckus Super Scooter Search Of Massive Results
