This is by far the best flowing intake system I have yet to try! This hose flows incredibly well. I had to richen my mixture 1/2 turn from my previous " snorkel" setup with the same filter.
I did however have to trim 1/2" off the carb end to clear the stock fender. I have about 3/8" clearance afterward.
What is the dimension of the mount from hole centers? The reason I ask is because after trimming the 1/2" off the hose it moves the hose farther forward. When I sit on the scooter I have almost zero clearance with the suspension compressed. If I was to use this mount I'm almost certain the frame will come down on the hose and bend the mount?
I noticed the ruckus shown has a shock extension installed and it appears to have a ton more clearance than I have on mine not sure if that's the reason or not?
I appreciate the time you spent to find this.
