EF Honda EF
    Posts: 308 Location: Linthicum Heights, MD & Roanoke, VA Gender:
Post subject: Re: 11 Pole Stator. Do you have these wires??? Posted: Thu May 10, 2012 6:53 pm |
ElCapitan wrote: Yea I saw that, and got confused because I've been seeing other diagrams that say different. Check out these two... Near the bottom of this page... http://scootdawg.proboards.com/index.cg ... read=212532nd post of this page... http://thescooterprofessor.proboards.co ... age=1#7460Right now I don't have it going anywhere, and it doesn't seem to be hurting anything, but I'd still like to do get it connected. That Is so odd. Both of them say it provides power. Have you happened to hook a multi meter upto the black wire and ground while the bike is running to see if it actually puts out power? Also, since you don't have that hooked up, I'm assuming all your accessories (lights) are run off the red wire?
_________________ 09 Yellow Ruckus viewtopic.php?f=92&t=22012&p=920376#p920376
| Top |
BDXRuck
   Posts: 361 Gender:
Post subject: Re: 11 Pole Stator. Do you have these wires??? Posted: Thu May 10, 2012 8:42 pm |
Congratz elCapitan  Contrary to the picture in my own guide, the black wire is usually ( but not always!) a positive voltage reference for the internal regulator circuitry, and should be connected to +12v. I recommend this procedure for deciding where to tie in the black wire: 1. Measure DC volts across the battery while running the engine. It may be bouncy or well below 13.5v ~ 14v. Take note of fluctuations in the charging voltage. 2. While still taking measurements, jumper the black wire directly to the positive side of your battery. Look for the voltage levels smoothing out or rising to more optimal levels (14v or so). If this happens, the black is most likely meant to be connected to +12v (switched) power. If not, it is most likely meant to be tied to ground. HTH
| Top |
EF Honda EF
Post subject: Re: 11 Pole Stator. Do you have these wires??? Posted: Fri May 11, 2012 5:47 am |
BDXRuck wrote: Congratz elCapitan  Contrary to the picture in my own guide, the black wire is usually ( but not always!) a positive voltage reference for the internal regulator circuitry, and should be connected to +12v. I recommend this procedure for deciding where to tie in the black wire: 1. Measure DC volts across the battery while running the engine. It may be bouncy or well below 13.5v ~ 14v. Take note of fluctuations in the charging voltage. 2. While still taking measurements, jumper the black wire directly to the positive side of your battery. Look for the voltage levels smoothing out or rising to more optimal levels (14v or so). If this happens, the black is most likely meant to be connected to +12v (switched) power. If not, it is most likely meant to be tied to ground. HTH Great info!^ Its annoying how many different stator slash rectifier's there are out there.
| Top |
ElCapitan
    Posts: 192 Location: Annapolis, MD Gender:
Post subject: Re: 11 Pole Stator. Do you have these wires??? Posted: Sun May 13, 2012 12:14 pm |
Yea I'm getting over 18v while reving, 14v +/- at idle with the brakes applied and headlight on, but it's always very sporadic and jumps from 14-20ish in all scenarios. It's currently a single 55 watt bulb up front, and here I thought the headlight would still drain too much. lol. I only get about .3-.5v off the black (to ground) with it disconnected, so I did the black to battery positive jumper test like BDX suggested and it leveled off to a little over 15v at the battery while reving! I'm going to make it a permanent jumper and hope it works out for the long haul. lol. Cabin Fever is 5 days away and I'm not messing with it any further for now. BDX, thanks again for all your help and sharing your wisdom! I owe you a few beers! As for the 5 wire "11-pole" rectifier, and the apparent floating ground trigger on the 11-pole stator I got from Scrappydogscooters, they are still a mystery. If anyone has any issues or input on either of those, post up here because they don't take electrical components back once installed, so I hope I can find some way to use them. To all others planning an 11-pole upgrade, I hope you're reading this!!!
_________________ ElCapitan
Check out my turbo GY6 build!!!
| Top |
ElCapitan
Post subject: Re: 11 Pole Stator. Do you have these wires??? Posted: Mon May 14, 2012 5:56 am |
I find it hard to believe that nobody has told them that they don't work before. That means they work for someone, or nobody has bought them before. And since they literally told me they don't know how to wire it up, I've suggested to them that they should test it out to find a way to get it to work, so we'll see. That or take them off the site since they don't work!!! lol
Also, from what I've been reading, the 8-pole and 11-pole flywheel rotor are the same, so they've gotten another $30 out of me. Seems misleading to customers, or they're clueless about their own products, neither of which instills a lot of confidence.
I'll keep doing research on it. I'd like to use these parts somehow too. Let us know if you figure anything out with it!
| Top |
EF Honda EF
Post subject: Re: 11 Pole Stator. Do you have these wires??? Posted: Mon May 14, 2012 8:41 pm |
ElCapitan wrote: I find it hard to believe that nobody has told them that they don't work before. That means they work for someone, or nobody has bought them before. And since they literally told me they don't know how to wire it up, I've suggested to them that they should test it out to find a way to get it to work, so we'll see. That or take them off the site since they don't work!!! lol
I'll keep doing research on it. I'd like to use these parts somehow too. Let us know if you figure anything out with it! ^well I actually just went though the same 11pole and 8pole flywheel deal. They both have 8 magnets in them (I placed a screwdriver on the inside of the flywheel and rotated the flywheel counting the magnets) BUT the 11 pole flywheel has a larger inner diameter than the 8. My 11pole stator fit inside my 8pole flywheel, but there are variations of the 11 pole stators that are larger and actually require a larger flywheel. My buddy has an 11pole that did not fit inside my 8 pole flywheel.
| Top |
