El Ruckuso
Troll
    Posts: 2287 Location: San Mateo, Cali Gender:
Post subject: Re: Questions and Answers regarding Carbs, Engines, Performance Posted: Tue Oct 19, 2010 8:38 am |
jc250r31 wrote: El Ruckuso wrote: I've got a carb question for you... I think this might be a simple problem I have an OKO 28mm.... has run fine in the past. Re-installed it on a different bike, and now- it idles fine, but as soon as I give it any throttle, it dies. How different is the other bike from the one it is installed on currently. Sounds like it just needs to be rejetted for the new bike it is now on. Could be... went from a stock GY to a 180cc... I'll have to mess around with the jets
_________________ The El Ruckuso Custom Forward Peg Mounts
The El Ruckuso Project: MANIMAL
| Top |
codename_OBAMA
 Posts: 109 Location: HAWAII Gender:
Post subject: Re: Questions and Answers regarding Carbs, Engines, Performance Posted: Sun Jan 01, 2012 4:24 am |
El Ruckuso wrote: jc250r31 wrote: El Ruckuso wrote: I've got a carb question for you... I think this might be a simple problem I have an OKO 28mm.... has run fine in the past. Re-installed it on a different bike, and now- it idles fine, but as soon as I give it any throttle, it dies. How different is the other bike from the one it is installed on currently. Sounds like it just needs to be rejetted for the new bike it is now on. Could be... went from a stock GY to a 180cc... I'll have to mess around with the jets I read somewhere that we need to re-jet to smaller jets for the 28-30mm oko carbs when we use it on the gy6. I'll be using this set up also so I'll be back on here when I do the swap
_________________ BUILD THREAD--> STEALTH BOMBER viewtopic.php?f=92&t=74925
| Top |
Strokd_GE
  Posts: 5008 Location: Central FL Gender:
Post subject: Re: Questions and Answers regarding Carbs, Engines, Performance Posted: Sun Jan 01, 2012 8:37 am |
AZRUCKR wrote: I am getting a pe20 carb and wanna know what needs to be done about TPS and IAC sensors? Nothing, just unplug them and leave them off, if you want to get fancy then you can unwrap the harness and remove the unused wires Were currently running my buddies stock ruck without both of these and it still runs fine
_________________ OFFICIAL PC Crazzies Street Team Member
Elite SR50 slammed with GET Powurr <CLICKY That new new '13 Metropolitan <CLICKY
| Top |
